7 members (baldeagle, Hotrod Lincoln, Bill Hanlon, fonz8261, greenie-reddy, 2 invisible), 367 guests, and 4 robots.
Topics128,162
Posts1,057,068
Members48,463
Junior Member
Junior Member
I'm searching for a brake cylinder, 51 Chevy 1 1/2 ton, 4100 series, rear wheel, the 'forward' or slave cylinder (each wheel has two cylinders, the aft cylinder accepts the main brake line coming in from the chassis and has a 3/16 line going out to the slave, and what I call the 'slave' sits on the forward side of the wheel and takes a 3/16 line from the aft cylinder inside the wheel.
See Figure 40, right side of page at: http://chevy.tocmp.com/1948_51truckshop/51ctsm0521.htm
Someone rebuilt these brakes and used 1/2 ton parts, plus one of mine has a deep grove.
See Figure 51, bottom of page, at: http://chevy.tocmp.com/1948_51truckshop/51ctsm0525.htm
Photo at: http://www.ankisolutions.com/1951Chevy-AsPurchased.html
Truck as purchased[/URL]
1951 Chevy 1 1/2-ton flat bed/tilt bed 4100 series
3B Offline
Hy Link Shadley, Try looking for United p/n 14499 they may still be available, hope that helps
Napa has them new,but are too costly.I sent my old ones out to White Post Restorations in Virginia.They overhauled them and sleeved them for much less $$.Try www.whitepost.com
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
