7 members (Steelonsteel, Otto Skorzeny, Robert Crandall, Charles in CA, JW51, mick53, Gdads51),
128
0
Mod | | | Forums66 Topics128,109 Posts1,056,267 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2022 Posts: 43 'Bolter | | 'Bolter Joined: Dec 2022 Posts: 43 | My Road Draft Tube always has oil coming out!. Is this normal? | | | | | Joined: Jan 2022 Posts: 2,459 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,459 | If oil is not coming out anywhere else, consider yourself lucky. It is "normal" on an engine with lots of miles, blow-by, etc.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Dec 2022 Posts: 43 'Bolter | | 'Bolter Joined: Dec 2022 Posts: 43 | Thinking about the changing over to something like the Deve's PVC kit.
Anyone done that? | | | | | Joined: Oct 2021 Posts: 6,822 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,822 | It looks intriguing but I think the pcv valve might be too low on the engine. Will the intake manifold start sucking oil out of the crankcase? I'm sure someone here might have experience with it to share.
With the road draft tube, the air has to travel up about a foot or so through a filtering mesh to keep the oil inside the engine.
If it works, it's an elegant solution without the need to hack up the valve cover.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2004 Posts: 29,804 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,804 | Better buy some stock in an oil company if you use that Rube Goldberg setup. The PVC needs to be up around valve cover height on a baffled standpipe like the factory system to prevent liquid oil from getting drawn into the intake. Jerry
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Are you missing the baffle in the crankcase that shields the opening from oil splash? | | | | | Joined: Dec 2022 Posts: 43 'Bolter | | 'Bolter Joined: Dec 2022 Posts: 43 | Don't know, if I pull the tube will I see the baffle? | | | | | Joined: Dec 2022 Posts: 43 'Bolter | | 'Bolter Joined: Dec 2022 Posts: 43 | Is there any type of maintenance that is required? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Do you have a breather cap on the oil fill? Every vent. system needs 2 in & out openings for circulation.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | I soaked my draft tube in kerosene and let it dry. Worked well. Good luck
1950 Chevy 3100
| | | | | Joined: Jan 2014 Posts: 3,689 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,689 | Not saying this is what you SHOULD do…
But I placed a breather with PCV in the valve cover (from there connected to manifold vaccuum), and modified the road draft tube to be the source of clean filtered makeup air. Seems to work fine. But I haven’t done any really scientific testing.
I will say that it’s a big improvement over the blow-by just venting out of the draft tube and valve cover.
1951 3100
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Kilroy55 Other bolters mention a filtering mesh in theolden days we called that "hog hair"coarse fiber like in an oil bath original air cleaner. Might go thru your oil fill cap (that has modern "hog hair" with a PCV hook up. So true though that if that is your only oil leak your very lucky !! My side of our garage apron has some territory marks from my 51 !! It gets worse when I work on it too LOL. | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | I used the factory PCV setup on my 261, which uses the stand-pipe Jerry mentioned. I did not tap into the air cleaner for make-up air but rather used a filler cap with oil-soaked metal gauze for a filter. I figured that's what the factory put on for the road-draft setup so it was probably good enough for the PCV. Wrong. This works but only up to a point, that being if you run zero vacuum for more than a few seconds you can start to smell blow-by. As soon as the vacuum comes up to say 2"Hg the odor goes away. If there's no vacuum in the manifold the blow by will come out the breather; whereas with the road-draft system even at zero vacuum there is enough draft from the air moving by to create a draft so the blow by goes out the road-draft tube.
This is probably not an issue on a truck driven around town or on local farm roads etc. where zero vacuum rarely occurs but on a highway rig where you're pulling long grades at full throttle it's a problem. I will fix it when I get home from the long road trip I'm on. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Jun 2021 Posts: 157 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 157 | I used the factory PCV setup on my 261, which uses the stand-pipe Jerry mentioned. Yes, it makes much more sense, than the PCV conversion I see a lot, where they just pull out the draft tube completely, stick a PCV valve in that hole and call it a day (and than wondering why the valve is full of oil). The gases evaporating from your oil tend to go upwards - so sucking it out at the highest point ( i.e. valve cover) seems to be a good idea in my book. I mean - did you ever see a V8 with the PCV that goes down in the crank case? They are all at the valve cover - I guess the GM engineers knew what they where doing. I left the oil filler tube portion of my downdraft tube in place (just cutting the actual downdraft part and welding it shut - so it's just a oil filler tube now), also I put a filtered breather cap on it. So I got circulation from the crankcase to the valve cover, and not vice versa - like a lot of folks do for some reason. Frank
| | | | | Joined: Dec 2022 Posts: 43 'Bolter | | 'Bolter Joined: Dec 2022 Posts: 43 | Yep, I have a vent cap on the valve cover. | | |
