2 members (Otto Skorzeny, 1 invisible), 102 guests, and 1 robot.
Topics128,154
Posts1,056,856
Members48,456
I'm in the research phase of my restoration. I'm curious what the differences are between the 100 and the 150. Are the frame and body the same?
I want to upgrade the axles, suspension and brakes. While doing that I'm considering switching to 150 components to improve the hauling capacity.
1958 GMC 100 Stepside
w/I6 270 Frame Up Resto
In the DITY Gallery
Frame, 6 lug wheels vs. 8 lug, brakes, rear axle and ratios, front axle, springs, maybe wheelbase and bed length (150 didn't have a short bed), tire/wheel sizes and a heavier duty Hydra-Matic transmission if you have an automatic are different.
Cab, radiator and mounting hardware, front sheet metal and bed sheet metal is the same assuming the same wheelbase. Electrics, engines and manual transmissions are the same.
