2 members (Jay R, Donf),
71
Mod | | | Forums66 Topics128,026 Posts1,055,405 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I installed an electric wiper motor, but it doesn't seem to have all the necessary range of adjustment or something. to get the passenger side to not be over center, I have to adjust the motor so far the driver side wiper only makes about 2/3 of a swipe, and the passenger side still flaps something awful. I read somewhere, that maybe bushings were bad? I bought all new linkage? Any ideas of improving the situation/ Thanks... | | | | | Joined: Sep 2009 Posts: 5,777 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,777 | brokenhead,
Just a note that it may help folks answer your question if we know more about what "electric" product you purchased/installed???
Also helps to know "what" it is installed in??? (Year/make/model, etc.)
Once we know, folks with similar equipment/set-ups can chime in to offer some help.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | I have New Port electric wiper motors on 2 of my trucks and it was a bear to set up. On one, I had to shorten the right side transmission arm to keep it from binding everything up, preventing me from adjusting the motor position to get full sweep of either blade. You may want to contact New Port and see if they can help you. If they cannot help you, I suggest that you only connect the left side wiper transmission arm to the motor and adjust the motor position to obtain full sweep and proper park position when you turn it off. Once you have that done, with the motor off, put the end of the right side transmission arm on the motor and see what you need to do to get full sweep out of the right wiper in terms of lengthening or shortening the left side transmission arm.
| | | | | Joined: Oct 2021 Posts: 6,696 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,696 |
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Oct 2021 Posts: 6,696 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,696 | NewPort's facility looks like a chicken farm.
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | I installed Newport wipers on my ‘46. They were not exactly an easy install, but the instructions were easy to follow. Didn’t have any problems with testing afterwards. Worked well in the only light rain event encountered since. Most, if not all, my street rod buddies have used the product too and at least from my recollection they never complained about having a problem either. I’m certain a couple of them being as they were, meticulous to almost maddening, would have said something since they were in the group of guys I talked to about a product recommendation. | | |
