3 members (Opelika Tom, klhansen, dt235sd), 100 guests, and 3 robots.
Topics128,078
Posts1,056,283
Members48,441
#1481157 12/31/2022 3:06 AM
Leo
Offline
Moderator
Moderator
My truck is a 1986 C10. My understanding is that the square bodies all had the antennas in the windshield
. I want to install an aftermarket antenna and simply hide it under the dash. How does one access the rear of the radio? If I do it by feel, which side of the radio does the antenna plug into?
Leo #1481170 12/31/2022 4:29 AM
Leo,
If I recall correctly, the antenna cable is plugged in at the top right corner on the back side of the radio (large diameter coax style cable).
That's the top right corner as you are looking at the face of the radio installed in the dash.
At least that's where it was on my '81 C10. IIRC, it was tight getting up behind the dash, but doable unless you have factory AC. The factory AC ducting runs below the radio, making it almost impossible to get to without removing the duct first.
A word of caution, there be sharp sheet metal edges and exposed screw threads under there that tend to bite you. eek
Hope this is helpful.
Happy New Year! yahoo
~ Dan
1951 Chevy 3 window 3100
Moderated by  truckernix
