0 members (),
200
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 24 Junior Member | | Junior Member Joined: Apr 2006 Posts: 24 | I put in a new brake master cylinder in the 66 c60, and now I'm having trouble with the push rod linkage. When I depress the brake pedal, to bleed the system, it only goes in a small distance and seems to bind up. The linkage does have some slop, but not alot. Any ideas or am I doing something wrong? Thanks Bill | | | | | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | is that pushrod adjusted to long? its not lettin the back pressure off the MC, it has to come all the way back to let off...
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
| | | | | Joined: Apr 2006 Posts: 24 Junior Member | | Junior Member Joined: Apr 2006 Posts: 24 | Hey thanks Fatweed for your help. I tried what you suggested and found through trial that the rubber connector between the main and line to hydrovac was plugged solid. I think that's my trouble/hope. Bill | | |
