| | | Forums66 Topics128,188 Posts1,057,220 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2020 Posts: 53 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 53 | Hope everyone had a nice Christmas. Does anyone know were I could get a power brake and dual master cylinder set up that would work on a 42 chevy dump truck. Seen a lot for 47 to 54. Thanks
Bah
| | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | I think you're on your own, I don't think anyone makes a kit for anything bigger than a 1/2 ton truck and they are to small for your truck. Rebuild the factory brake system and move on... Mike B  | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | I should finally have parts from my machinist the first of February for my disc brake conversion kits that uses a modern master and booster that is located in the same spot as the factory master. It eliminates the hydro vac and adds 15" disc and dual piston calipers up front. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | I should finally have parts from my machinist the first of February for my disc brake conversion kits that uses a modern master and booster that is located in the same spot as the factory master. It eliminates the hydro vac and adds 15" disc and dual piston calipers up front. Sorry Randy, I completely forgot you were making kits...my bad! Happy New Year! Mike B  | | |
