7 members (gswbbc, TUTS 59, jmoore, Brian Moore, tclederman, Steelonsteel, BC59), 82 guests, and 3 robots.
Topics128,031
Posts1,055,435
Members48,422
#1474638 11/09/2022 11:26 PM
I need to be educated by the paint pros. I am getting my truck painted black. I was told by the shop they gave multiple black paint codes. Help? Isn't black black? If I have to pick a black code I guess I could use the original black paint code?
Dave from Northern Kentucky
My 54 3100
dgrinnan #1474639 11/09/2022 11:29 PM
Apparently the new black isn’t black! nanner
dgrinnan #1474648 11/10/2022 12:36 AM
There’s about a bazillion shades (or names) of black now. Check the tech tip and see if your paint guy can use the PPG code if you want the “original” black.
dgrinnan #1479095 12/15/2022 10:07 PM
Be glad you are not painting it white. There are more shades of white than you could count between now and Saint Swivens day!
dgrinnan #1479961 12/21/2022 11:02 PM
I used Nissan black from a 2005 truck- KH3 Black Obsidian/Super Black.
1940 1/2-ton
Low skill and low buck build
Follow in the Project Journals
In the dark of night, she's a looker.
dgrinnan #1479962 12/21/2022 11:15 PM
I used PPG DCC9300. It is suppose to be the blackest black.
1946 with WWII 270
dgrinnan #1479964 12/21/2022 11:55 PM
2 Offline
Don’t tell Anish Kapoor he will come over and see your truck and sue you! Lol
( Vanta black joke and the controversy around it in the art world)
-s
dgrinnan #1480035 12/22/2022 5:16 PM
Curmudgeon
Curmudgeon
First you have paint type:
Acrylic lacquer
Acrylic enamel
Acrylic urethane
Water-based (that's a new one to me)
Paint appearance:
Solid
Metallic
Pearlescent
Matte
Black pigments:
Musou (99.4% light absorption...looks weird)
Carbon black
Jet black
Lamp black
Channel black
Bone black
on-and-on....
Rattle can black (mystery spray can mixture at your local store)
The most commonly used are Jet and Lamp black.
Since paint pigment can be blended, of the same paint type, you can multiply the combinations of black.
The shininess of the paint as well as clear coat can alter color as seen by the eye.
Some people say they can see a slight tint in one-color black paints. A red and blue tint. Blue tint preferred.
Henry's Model T used tung oil, car black pigment plus gilsonite.
FYI, PPG 9100 listed as 1954 Chev. truck "Jet Black" same formula as PPG 9300.
