6 members (TUTS 59, Ponchogl, Steelonsteel, Gdads51, Gray_Ghost, ESum), 92 guests, and 4 robots.
Topics128,088
Posts1,056,125
Members48,435
#147875 08/13/2006 10:12 PM
Junior Member
Junior Member
Does anyone know where to get rebuild specs on a Rochester 4GC for a 59 spartan 100 with a 348???
spartan 100
72 GMC 1500 4X4
72 GMC 1500 BURB 4X4
72 CHEVY CHEYENNE 2500 4X4
59 CHEVY SPARTAN 100
#147876 08/13/2006 10:28 PM
3B Offline
Hy Spartan 100, the quick answer would be from a 59 maintenance manual, what exactly are you looking for?
#147877 08/13/2006 10:31 PM
Junior Member
Junior Member
Looking for float level & drop measurements. I found a rebuild kit but it came with instructions for a Q-Jet. I would love to find a maintenance manual for my truck.
spartan 100
72 GMC 1500 4X4
#147878 08/14/2006 4:21 PM
3B Offline
Hy Spartan100, primary float level 1 43/64" secondary float 1 47/64 drop is 2 1/4" for both floats, pump rod adjustment is 1 1/16" hope that helps.
#147879 08/15/2006 12:35 AM
Junior Member
Junior Member
3B Thats a huge help. Where did you find that info. I am having a hard time finding tuning info(timing, point gap, dwell ect.) I don't think Chiltons goes back that far. Thanks again!
spartan 100
72 GMC 1500 4X4
#147880 08/15/2006 1:05 AM
3B Offline
Hy again Spartan100, spark plugs AC-42N gap .035, cam angle [ dwell ] 28-32 degrees, point gap .019 [new] .016 [used], timing 4 degrees BTDC, valve clearance hydraulic 3/4 turn after zero, lash idle RPM 475 with standard trans., hope that helps
#147881 08/15/2006 2:27 AM
Junior Member
Junior Member
Thanks! I owe you a cold one
spartan 100
72 GMC 1500 4X4
