3 members (Wheelie, 1955 1 Series, Otto Skorzeny), 40 guests, and 6 robots.
Topics128,012
Posts1,055,315
Members48,419
#1478004 12/08/2022 2:03 AM
I am in the assembly stage of my wiring harness installation. As of right now I have a machine screw mounted on the firewall that is attached to bare metal on both sides that I am using as a ground for all things on the dash and firewall, is it a good idea to use one common ground like this? I am going to bond the frame to the chassis and run battery neg to engine block and chassis. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Less places to look for a problem, so yes I think it is a good idea.
O Online: Content
I would use a junction block rather than a stack of ring terminals stacked up under a single screw.
I would connect that junction directly to the battery, frame, engine, and body.
1950 Chevrolet 3100 (Ol' Roy)
Sir Searchalot
Sir Searchalot
Most dash components are self grounding usually. What ground wires for "dash things" are you talking about ?
What ground wires for "firewall things" you are talking about? Not many of that type either.
What vehicle?
You can't have too many grounds but what you are doing sounds a little odd so far.
One grounding point- - - - -no!
Sheet metal screw to attach the ground(s)- - - - -"L" no!
I'd use several ground wires and attach them with a machine screw and nut at both ends.
Crusing in the Passing Lane
And if your vehicle has been painted, scrape off the paint to get a good ground. A Q-tip is your friend for holes drilled after painting!
Ed
Good grounds are very important. Single point grounds have important applications in some electronic and electrical situations, but I'm not so sure that it matters in automotive DC applications. Personally, at most grouind connections, I bare the metal, then use star type lock washers on both sides of the connection. Also, in agreement with previous post, I would never use sheet metal or tapping screws for any electrical connection. I would use machine screws / bolts, with lock washers and nuts.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
And use some sort of anti corrosion protectant, I use my old battery terminal protectant for such things, or vaseline, etc.
Especially if removing paint.
I started this thread stating that I was using a machine screw on the firewall and I had stripped both sides to bare metal. I don’t understand why you think I was using sheetmetal screws or anything less.
1941 Chevy
Homer is getting a bum rap here.
homer52 Suppose you could mount a junction block with larger wire to ground then use screws on a few grounds coming there.
I have a ground bus and a power bus in my '28 Canopy Express. These are primarily for the light and ignition circuits.
The power bus is mounted on a piece of 1948 hardwood floor material.
The ground bus is a flattened copper tube that is grounded to the firewall.
Cheers, Dean
Electrical buses in Justin.
Dean 'Rustoholic' Meltz
Lurch: 1927 1-Ton Chevy Cattle Truck
Old and ugly is beautiful! -- The Saga
Lurch's Gallery
Justin: 1928 Chevrolet AB Canopy Express
Sir Searchalot
Sir Searchalot
Agreed,
Homer, several grounds on one screw/bolt is just fine.
