8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible),
159
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | Can my 46 fuel tank sender be rebuilt? It looks like a sealed unit, the gauge is buried on full, I was playing with the sender and it started reading for a few seconds. I put in another sender and it works fine but I'd like original equipment. | | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | There are companies out there that rebuild them so there's no reason you you can't try. You've got nothing to lose since it isn't working now. If you're able to repair it, great. If you aren't, you'll have lost nothing but time.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | The pickup inside the sender has fallen apart, anyone know of a source that I can buy a new one? | | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | Here it is. Best and most accurate available.
https://www.ebay.com/itm/261122347319?hash=item3ccc1ad137:g:FBgAAOSwpPVgBuwZ&vxp=mtr
