0 members (), 254 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
After purchasing our 51 3100 1/2 ton a couple of weeks ago I decided to do a fresh oil change.
The motor is an upgraded 253 from a mid 50's sedan.
What has got me perplexed is the contraption at the drain plug and I am wondering if anybody has seen this before?
Clearly aftermarket. Its not a petcock. if I remove the screw it is not threaded all the way into the drainplug. Then you can see the adaptor as well.
Is this some type of anti back out device?
the center drain plug has an o ring on it and not a gasket.
Curious what you all think.
51 Chevy 3100
43 Willys MB
45 Willys MBT
45 Willys CJ2A (10578 & 10910)
45 Bantam T3C
61 Chevy Corvette
He is no fool who gives that which he cannot keep to gain that which he cannot lose. Jim Eliot
That appears to be a repair kit for a damaged thread in the oil pan. The big plug probably has an oversized, self-tapping thread and the middle plug is then used to drain the oil. The bracket that's held on by the screw is a safety device to prevent the plug from getting loose and backing out. The inventor of that device was probably a gentleman named Goldberg!
Did you post this picture in another thread? If not, then someone else on here has the same oddball thing.
Is the first, smaller nut the drain plug? Is the large nut against the pan fixed in position?
1950 Chevrolet 3100 (Ol' Roy)
Clearly German engineered. When hiring engineers from the Old Country (my people refer to us as such), it is always advisable to hire two of them. One to come up with all of the ideas, and the other one to tell him when to stop engineering.
Since the threads for the part which uses the o-ring can only be tightened enough to compress the o-ring, but not tight enough to prevent it from backing out from vibration, an additional device was required to prevent that.
All and all, I'd say that Otto stopped Hans from 'engineering' this device too far.
But given my ethnicity, I may be biased.
I did post a picture of it in the "what did you do today" section after I spoke about what all I did to the truck that day on the truck but the posting was taken down. I apologized for not staying on topic with "what did you do today" Basically I said I found this odd ball plug.....
Anyway, I have not attempted to take out the larger hex head against the pan. I loosened the smaller one saw the o-ring and figured that would be the drain, which it was.
Just have never seen that type of "safety" contraption
51 Chevy 3100
43 Willys MB
45 Willys MBT
45 Bantam T3C
61 Chevy Corvette
