0 members (), 54 guests, and 2 robots.
Topics128,049
Posts1,055,743
Page 2 of 2 1 2
Perfect! Thank you!
Carburetion specialist
Originally Posted by Workinprogress
Thanks for the reply gentlemen!
The carburetor does have a 1-1/16 cast into the side of it! That was a full on lesson on Holley carbs and that’s exactly the type of learning I am here for and my reason for being here. I am hoping the carb rebuild kit I ordered will fit it. It says AA1 on the box…
Thanks for the input! I like not only knowing the difference, but also why!
Hopefully - the box also says G.M.C., not Ford.
Between the two:
Flange gasket, throttle body gasket, and air horn gaskets are the same.
Fuel valve (a.k.a. needle & seat), accelerator pump, idle mixture screws, main metering jets, and economizer valve are different.
Jon
The Carburetor Shop
Thanks Carbking… I think it had a couple of part numbers on the box, I will have to look and see what exact models it fits. I didn’t know there were several of the “same” carb…
Actually, a few more than "several"; I have 125 different listings in my database for the AA-1 plus another 56 different of the type 2100-DD that most folks erroneously call a "94". This is the type Jerry mentioned that he installed on his modified Ford.
Hope the kit you have works for you.
Jon.
The Carburetor Shop
Page 2 of 2 1 2
