1 members (NJC), 78 guests, and 0 robots.
Topics128,035
Posts1,055,564
#1476002 11/20/2022 4:04 PM
Hi guys, this time I'm having fun with my master cylinder.
The MC is a generic dual cylinder (often called "Corvette MC") with a booster- it sits under the floor of my 41.
Dual drums - residual valves and a proportioning valve in the rear line.
Here is the situation so far:
1 - The brakes where working great with this setup, but the car sat for 10 years, so of course the brakes needed some love. The front cylinders where shot so I replaced them.
2 - rear cylinders looked good (at least not leaking like the fronts).
3. Did a test drive, but was not happy with the brake performance (I remember that it used to be way better).
4. Took the MC out - disassembled it, no rust/crude/slush, rubber looked good - I just blew it out and cleaned everything.
6. Refilled with fresh fluid, bench bleeding - worked like a charm, everything seemed fine with the MC.
7. Put it back in the car, started bleeding the rear with a vacuum bleeder - no fluid coming.
8. I removed the proportioning valve and also the Wilwood residual valves (since I was told that they are carp) to rule those out.
9- New vacuum bleeding attempt at the rear wheels - no fluid coming no dice.
10- Tried the vacuum directly at the MC (just with a short piece of brake line) - no fluid coming.
I'm out of ideas.
Frank
3B Offline
Hy Stovebold6, short of a hole somewhere in the system not allowing the vacuum to draw fluid when you try vacuum bleeding at the rear, I don't know what might be causing a problem. You said it won't draw fluid from a short line right from the master cylinder, will it pump fluid if you use the pedal? Have you verified your vacuum pump is working and not leaking internally?
B Online: Content
If the pedal isn't "all the way up" you won't get any fluid you won't get any fluid.
Brake lines collapse from the inside. Pull your rubber lines and see if they are open.
Good call - I will check that. The Return spring may be a bit on the weak side.
thanks, Frank
