| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 772 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 772 | I've got a couple clickers (1/2" and 3/8") and an old Craftsman 1/2" pointer (gift from Mom and Dad about 50 years ago). I'd like to upgrade to the digital torque wrench. Can anyone recommend a decent brand that's reasonably priced? | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | Define "reasonably priced". What range do you need? Do you want/need to do angle measurements for TTY bolts? I recently bought this one when I was replacing the heads on my suburban and it is really nice: ACDelco ARM303-4A-340 https://a.co/d/a2kkFSII particularly like that it starts beeping slowly as you approach the set point, then vibrates and goes solid when you reach it. It also gives you final torque values that you can check to see if you overshot (or see what TTY bolts ended up at). I would not hesitate to buy it again, but it was not cheap. | | | | | Joined: Dec 2013 Posts: 772 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 772 | Good questions. This is a tool that I would probably use about a dozen times a year. The clickers I have are from a FLAPS. They have served me well over the years, but after a while I question the accuracy of them. I had to replace the 1/2" drive under a lifetime warranty earlier this year.
As far as reasonable cost, I could certainly justify $250-$300. I need something for up to 200 inch pounds and one that would work for up to 200 foot pounds.
I'll take a look at the ACDelco torque wrenches. How would I check the ones I have for accuracy?
Thanks, | | | | | Joined: Sep 2020 Posts: 438 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 438 | I have checked mine against my old school beam torque wrench, not much to go wrong with those as long as the pointer starts at zero.
Hank: 46 Chev 1/2ton shortbed 2023 Miata RF Club | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | I would not hesitate to buy it again, but it was not cheap. That's a bargain at twice the price! In fact, somewhere in the neighborhood of $400 is what I spent on my last click type. If it sets anyone's mind at ease, we have some 3/4" drive, click type that have been abused and thrown in to drawers for the last 30+ years or so. A few years back they bought all our shops some torque wrench checkers. Those old wrenches were still accurate! | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | When I was doing warranty claim inspections I used a Snap-On click type wrench that had to be calibrated once a year. It never failed to pass the annual check, with little if any adjustment required. The big thing to remember is to release the spring tension on the adjustment immediately after the wrench is used. Leaving the wrench adjusted to a specific torque can result in the spring taking a set and getting inaccurate at other settings. Jerry
| | | | | Joined: Oct 2021 Posts: 6,705 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,705 | Read the manual!
I remember seeing that in the instructions in all three torque wrenches I've had my whole life. I always set them to zero when I'm done.
I also check one against the others to make sure they're all accurate. I've never had to calibrate any of them. Maybe they're all inaccurate by exactly the same amount?
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | The yearly calibration was needed in case I might get called to be an "expert witness". The few times it looked like that might happen, the legal beagles read my report and decided they really didn't want me making monkeys out of them on a witness stand and either dropped the suit or settled out of court. Jerry
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | I've run/programmed, multimillion dollar cnc machine tools, and I still don't trust any electronic digital anything. I've had digital test instruments fail many times. Your plain SOL if the battery goes dead and you can't get a new one right away.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Jan 2017 Posts: 62 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 62 | I've had really good luck with Precision Instruments split beam torque wrenches. They're identical to Mac but can find them really reasonably priced on the internet. | | |
