Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
7 members (DJHobbit'46Chevy, Danielbolt, GMCJammer51, Dragsix, RBs36, 2 invisible), 568 guests, and 1 robot.
Topics126,780
Posts1,039,295
Members48,100
Most Online2,175
Jul 21st, 2025
#1474851 11/11/2022 2:36 PM
Been a few years since I have been on the forum , couldn’t log in with old account .
Either way , needing body mount bushings .
Anyone have a alternate , Only supplier
I can find is truck and car shop in California, been on back order for ever part 60-09605.
Suggestions greatly appreciated, 61 is the odd duck
Authorized Pest
Authorized Pest
Eric,
If you are interested (would be easier for you) ... Your old screen name seems to be:
61 suburban
Log in and you can request the "password" if you can't find the original one. Here to help if you need it.
Peg
~ Peggy M
1949 Chevrolet 3804
In the Gallery || In the Gallery Forum
"I didn't see this one coming. I don't see much of anything coming. :-O"
Did you try Brothers? It is now Holley.com. Is that the California company you are referring to?
Regards, Mark
1958 GMC Suburban Carryall
Never accept a drink from a urologist!
Thanks for the reply , no the company is
http://www.truckandcarshop.com/.
I looked on brothers at one time , I will look again.
Hi Peg ,
Sure that would be great .
Authorized Pest
Authorized Pest
Eric,
You just need to log-on as 61 suburban ....
(Can't PM you here with "moderated" status!)
~ Peggy M
1949 Chevrolet 3804
Brothers was a wash , still on the hunt
Eric
If they're just the square pads that car and truck shop shows in their catalog, with a hole in the middle and maybe a sleeve around the bolt, it wouldn't be hard to build a mold and cast your own from polyurethane. It's available from a number of sources in 2-part form that you pour into the mold. I've rehabbed my axle and transmission mounts using that process. Silicone grease works as a mold release.
If that's the case, find some "elevator belt" in the thickness you need. Cut to size. Last stuff I worked with was some 1.5" thick 4"x4" air compressor pads. Or something like that.
Interesting, any suggestions on a two part kit ?
I’ve considered this, I have 1/2” belting . There is a sleeve inside the bushing , I would need to figure out how to incorporate.
Originally Posted by klhansen
Eric
Which type of poly did you use? I have experimented with a couple different types but never found anything that looked durable enough to use for mounts. I have a couple things I would like to recast.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
I used Simple Resin's Enduro-Flex product for my axle mount pivots. It looks like it's back available, as it hasn't been for a while. Link
It can be tinted if you want. Their tech department sent me this info:
Add pigment at ~2% of the total mixture to the Part B side and blend. Make sure its not a water based pigment.
Combine colored hardener and resin at equal weights or volumes.
Mix well for 20-30 seconds scrapping sides and bottom of mix container several times throughout mixing process.
Pour into cavity.
Thanks Kevin! I just ordered a batch to try.
Sorry haven’t posted on this topic in a few months. I resolved the issue using suspension.com universal mounts. I had to open the frame mount from 1.125 to 1.250 . Not sure how to add a photo here , guess I need to hang out more 😂 see attached and hope this helps . Ohh yah the difference in height did not interfere with other parts of the build .
those look like early mustang II strut rod bushings
1936 GMC T-14 restro-mod
Very similar ✅
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.064s Queries: 15 (0.061s) Memory: 0.6752 MB (Peak: 0.8061 MB) Data Comp: Zlib Server Time: 2025-09-22 20:44:38 UTC
Valid HTML 5 and Valid CSS
