3 members (oldsteve, doyle1950, frogfarmer), 167 guests, and 0 robots.
Topics128,087
Posts1,055,974
Members48,430
#1474645 11/10/2022 12:21 AM
jdl
Offline
Hello all, awhile back my neighbor recruited me to help work on a 48 ton and a half with a late 50s 261. After giving it a tune up, carb swapping and fuel pump it starts and idles fine. Anything above 1/4 throttle and it starts missing whether or not it's under load almost like you flip a switch. We're both scratching our heads on it. Exhaust is unrestricted, can't find any vacuum leaks, and timing is set correctly. The vacuum advance port is capped at the carb because of a bad diaphragm. Any ideas on what to check?
Thanks- Jordan
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #1474646 11/10/2022 12:27 AM
Reconnect the vacuum advance. It's a crucial component for smooth operation.
Check timing, plugs , cap, rotor, points, Condenser.
What kind of carburetor? Rochester or Carter?
Either way it could be flooding. Stuck float, debris in needle and seat, etc.
1950 Chevrolet 3100 (Ol' Roy)
jdl #1474659 11/10/2022 1:30 AM
There is a difference between 261 Rochester carburetors and 235s, so if it is a carburetor issue, it's probably under powered.
For a 1961 chevy 235, the main jet is .055.
For a 1961 chevy 261 the main jet is .063.
I put a 235 carburetor on mine to get it going, it worked ok, but accelerating off idle it would stumble and have a lean condition, would backfire. When I had it rebuilt the mechanic drilled the main jet out for me.
Pic is from 1961 chevy truck shop manual supplement. yours is a bit older but should be the same idea.
1961 Chevy C40 Flatbed 261
jdl #1474660 11/10/2022 1:36 AM
Check the points to make sure they have enough spring tension. Some brands of points have a copper conductor strip, and a steel spring that can get misplaced. Without the steel spring, the engine will idle, but the points start bouncing and messing up the ignition timing at higher speeds. A bad condenser can also cause the same kind of problems, and they're notorious for being bad right out of the box.
jdl #1474663 11/10/2022 2:16 AM
advance mechanism is not working
jdl #1474673 11/10/2022 3:47 AM
B Online: Content
I'm with Jerry on this one. I saw it happen 7+ years ago and again recently on this forum. If you have a dwell meter you can watch the dwell get less and less as the RPM increases. It should stay constant.
jdl #1475097 11/13/2022 4:46 PM
jdl
Offline
Thanks for the input guys! I'll check out the points and go from there.
Jordan D. Long
Photobucket
