5 members (Ponchogl, MickeyP, Bill Marlow, 48jim1ton, 1 invisible), 119 guests, and 0 robots.
Topics128,049
Posts1,055,553
Members48,425
#1474336 11/07/2022 8:00 PM
Hi all,
Can someone help me decode my engine serial numbers. I'm pretty sure this is not the original engine in my 53 3100.
Thanks!
Distributor side
Exhaust side
Exhaust side
1953 Chevy 3100 1/2 Ton Pickup
Doug
The number we really need to see is only partially visible. The stamped (not cast) number on the machined pad just behind the distributor will be more helpful in making an exact ID of the original application of the engine, as casting numbers have a tendency to apply across several production years and different original installations. An original equipment engine in a 53 3100 would have been a 216 with Babbit connecting rods, and the engine in your pics appears to be a later model 235.
Give us the rest of the "stamped" serial number and we should be able to tell you what it came out of.
Mike B smile
PS...was typing when Jerry posted the same info.
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Jerry it's really hard to read with the starter in the way. My best guess - CON4 L234
3836233
Sorry I misread your post...here is the "stamped" serial number - 0201682F55
Hopefully that helps!
Doug
The 3836233 indicates it's a late 55 235 block, as does the 55 at the end of the serial number, with the F indicating it was built at the Flint plant.
Here's the link for block casting numbers. Link
Thanks Kevin! That's very cool. Is there any way to trace the vehicle history? All I know so far is the PO had it for one year here in Arizona.
Doug
I don't have a reference table handy since the computer with that info in the "favorites" section has a bum power supply. The F55 suffix of the stamped number is what will most likely identify the engine's original application. Have fun!
As far as tracing a vehicle’s history, you’re probably out of luck. I know the original owner of my truck because it was orange and has a brass repair tag on the valve cover that says “Alaska Road Commission”. I was also able to talk with a previous owner as I had an 80’s registration document in the glove box. Other than that, DMV won’t release previous registration info because of privacy issues. Your state may differ. It won’t hurt to ask them though.
Can’t you get that engine any cleaner?
(Ha…)
(Ha…)
Actually, I noticed some residue building up since I brought her home and was wondering the best product to clean it?
wink
Doug
Careful ………….. if it ain’t leaking it’s out of oil! drive
Your missing one last letter after the F55 that would tell you what the engine came in...post a picture of the stamped number...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B smile
Hey Mike, I'm out on the road so I can't get another picture. This is the one I had before, but I don't see anything after the F55. I'll look again when I get back home.
Engine serial stamp
Doug
Looks like you'll need to scratch the paint off to see it as it was lightly stamped.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
