3 members (2-Ton, Steelonsteel, Donf), 108 guests, and 2 robots.
Topics128,034
Posts1,055,546
Members48,425
#1473953 11/05/2022 1:12 AM
where is a good place to buy some lifters? possibly push rods also. ARE the lifters the same as the 235-261??
Jay D.
jay d #1473963 11/05/2022 4:08 AM
none of the Chevy lifters have matching part numbers to GMC. When you start looking for 270 lifters you need to know if you want the deep cup (early) type (part # 2071209) or the milk bottle (late) type (part # 2194006). When I bent a pushrod on my GMC 228 I took it to FLAPS and they ordered a replacement by size. That was 9+ years ago and the counterman knew how to look at catalogs.
jay d #1474281 11/07/2022 1:22 PM
jay d If you run across any good lifter sources in your search let us all know please. Just ordered a set of EXPENSIVE offshore lifters,they don't have as much crown as some OLD original new lifter barrels I happen to have on my shelf. So don't know if I would trust them. Did buy a ccs-1 cam that looks fine is american I hope !!
fixite7 #1474300 11/07/2022 4:55 PM
i have had bad luck with the mike can style in my other engine 270. i finally got some years ago that are solid iron lifters much like a chevy V-8 would use they have been good for years.
Jay D.
