| | | Forums66 Topics128,047 Posts1,055,622 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | I know how to do that real well when the wood is out, how have you folks done it with the wood in? I can use a gantry hoist in the front and a cherry picker behind to keep stress low on straps. I thought about hooking the straps into the bottom of the stake pockets? I just don't want them bent. According to the info in the 57 salesman book the bed weighs 377 lbs, from memory. I plan to store it standing on the front.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: May 2015 Posts: 11,026 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,026 | You could lift the bed with or without wood in place by looping 1” strap behind the roll on each side without damaging anything. Or loop the straps across front and rear underneath. The bed is 16 gauge steel and won’t be hurt unless you tighten the straps too much. Leave enough slack so the straps are at 45 degrees to your hooks (of use a spreader bar.)
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I'm 85 so I have little use for our 2 post lift but it is a great body and bed lifter. The truck is backed in to where one set of arms can be attached to the front and the other set to the rear. Lift and drive out from under bed. Sometimes we remove wheels and put truck on skates if lift not high enough. For big trucks we spread the forks on the fork lift and can raise bed high enough to drive a semi under it with exhaust stacks in place. Have special made brackets that fit lift arms for Model A's or others with tall running board splash aprons. Especially like 2 post lift for setting body back on frame as it cam be worked a millimeter at a time.
Evan
