10 members (sron48, cmayna, Scott, 48jim1ton, frogfarmer, Wayne67vert, Wally / Montana, gswbbc, Gdads51, panel fan),
129
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 23 Apprentice | | Apprentice Joined: Aug 2004 Posts: 23 | Any suggestions on how to take apart a wheel cylinder. I have the end caps off and can see the cups with the bore size on them but thats where im stuck. How do I get them out? I dont want to tear them apart. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | They should push out easily. Are they still on the truck? Do they still have fluid in them? If so release the fluid. Take a socket and push from one side, out the other. If they have to be driven out, the cylinder probably needs to be rebuilt or replaced. | | | | | Joined: Aug 2004 Posts: 23 Apprentice | | Apprentice Joined: Aug 2004 Posts: 23 | They are off the truck and fluid out of them. I thought I would probably have to push them out but I havent done this before and didnt want to mess them up until I was sure. Thanks for your help!!! | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | I they are off of the truck you can try air pressure in the brake line hole. If still stuck block the brake line hole and apply a grease gun to the brake bleader this method has never failed me. If the gun nozel won't fit the bleader remove the bleader and use a needle attachment in the bleader hole this will need firm pressure. If you try to drive the pistons you will ruin the spring and probly the pistons. | | | | | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | if you put air to that stuck wheel cylinder, dont stand in front of it,,,it could blow ur head off... or a hole throught the wall anyway... thats dangerous... just hammer them out... theyre probably stuck with rust...as far as the spring goes it will come with a new kit alot of times... pistons wont but they usually just need cleaned up.. alot of them are aluminum and dont rust...whatever...just be careful puttin air pressure on anything that can come apart, the air will compress and when it blows it blows... the grease gun is ok for doin pressure on it though.. it wont blow, just kinda spurt a little hehehe....figure it this way.. what happens to a balloon with to much air..??? boom... fill a balloon with gease till it busts... spurt...LOL....
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
| | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Man don't waist you time overhauling wheel cyl.'s I use to do that cause you couldn't get new ones. It's a time vs. money thing, the time you take to o/h the cyl. won't be less than the cost of total replacement. Not to mention that you will have to buy a hone and then find out after honeing, the cyl. won't clean up enough to work safely. Just bite the bullet and put on new ones. Now o/h a caliper is a differant story, you will replace the piston and you don't have to hone the bore. Cost effective to o/h calipers. Please note that all the rubber in your brake system uses the same fluid,has the same wear, and is most likely to be in or nearly in the same shape. So if you replace one replace them all and you will be ahead of the game. Don't scrimp on brakes, if a car dosn't run well you can still go. If it don't stop don't drive it.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Yes throw the things away and get new ones. I've been able to buy every one i needed at the local parts house. I've never seen a rebuilt one that didnt fail somewhere down the road in a yr or two. | | | | | Joined: Jul 2006 Posts: 149 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 149 | Basicly? If you feel the need to take the cyl's apart???? remove the end caps.... wrap a shop rag over the exposed ends... and apply air press to the brake line port... but ONLY use enough pressure to "pop" the cups out... Michael \'48 chev 2-ton boom truck (Boomer) '49 Chev 2-ton flat bed '65 Chev 35ft school bus '88 GMC 6500 '72 Superior 26ft class "A" coach '50 Farmall "M" '71 MGB GT '68 Austin-Healey Sprite '65 Austin-Healey Sprite and various other odd British cars and lots of old radios..... Although we know what the speed of light is..... What I want to know is... How fast is the speed of DARK??
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I agree if new ones are available get them. If it uses aluminum pistons sometimes you can use snap ring pliers to get them out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
