| | | Forums66 Topics128,026 Posts1,055,409 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2022 Posts: 38 'Bolter | | 'Bolter Joined: Jul 2022 Posts: 38 | I'm looking to replace my fuel pump and have found several in the $55 range from several retailers and nobody indicates brand. So I looked at Rock Auto and they offer a Carter for $20...has anybody used a Carter replacement ?
'50 GMC 1 Ton Dually - Barn Find (sort of...no barn)
| | | | | Joined: May 2015 Posts: 11,002 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,002 | You have to be careful about the arrangement of the inlet and outlet. If your current fuel pump is still available, try a rebuild kit from Then and Now Automotive.IMO that's a better option than using an offshore produced pump that may or may not fit right and may not even work. To get the right kit, look for the number stamped in your fuel pump and then search for that on their site. Search string "[number] site:then-now-auto.com
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2021 Posts: 6,696 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,696 | Do what Kevin says. I recently went through a fuel pump fiasco wherein two Carquest fuel pumps proved to be useless junk - one of them right out of the box wouldn't pump a single drop. I sent my original glass bowl style fuel pump to Then & Now Automotive and it works perfectly. I elected to have T&N rebuild the pump for me because it was extremely reasonably priced. $52+ shipping for the kit if I did it myself. $115 for them to do it. $63 for seemed like a real deal to have them do it for me. They have the tools and jigs to remove the pin from the arm, etc. You can read about the entire debacle here: https://www.stovebolt.com/ubbthread...umps-and-other-nonsense.html#Post1463250
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | At the start of my project I needed a fuel pump, the original gas tank was not usable due to varnish and holes, new tank, new fuel lines, kit for the carb, ready for a pump. With mine being a V8 283 I knew I would have a world of options but for now I just needed something that would get it running. Bought the lowest priced simple pump from one of the national retail chain auto parts, that pump is still working, no leaks, starts and runs as it should with 5-6 years of use and regular pump gas with ethanol. I would like to rebuild the original AC pump but have not had a need so far.
