1930 looks to be correct, based on other photos on the web.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
Judging by the long running boards (versus shorties for the larger series), looks like it could be a 1-ton Universal LR set up as a road tractor. Looks like you can see a 5th wheel of some sort and the corner of a trailer in the pic.
~ John
"We are not now that strength which in old days Moved earth and heaven; that which we are, we are"
1948 International Farmall Super A 1949 Chevrolet 3804 In the Legacy Gallery | In the Gallery Forum 1973 IH 1310 Dump 2001 International/AmTran RE3000 "Skoolie" 2014 Ford E-350 4x4 (Quigley)
~ Peggy M 1949 Chevrolet 3804 "Charlie" - The Stovebolt Flagship In the Gallery || In the Gallery Forum "I didn't see this one coming. I don't see much of anything coming. :-O"
My guess is either a 1929 LQ 1 1/2 ton or a 1930 LR 1 1/2 ton truck.
It has six lugs on the wheels, which means it is a 1 1/2 ton truck. Also the radiator emblem is definitely from '29 or later.
The last year of that era for one ton trucks was 1928, model LP and was also the last year of the four cylinder engines. Directly after '28, the trucks offered were either 1/2 ton or 1 1/2 ton.
The 1930 AD shown by Peggy's link is a 1/2 ton truck because it only has four lugs on the wheels, which means it was built on a car chassis.
The truck in Bremquest's pic above is definitely not a 1932 because in that year, the hood louvers went the full length of the hood. Whereas in '29 and '30, the louvers only covered 1/2 of the hood.
As for the short running boards, that's what you got when you bought a truck without a bed and without rear fenders.
We did a 1928 1T dump truck with a 4 cylinder that had no provision for front brakes, the backing plates were just dust covers. Was this available from the factory? Was used off road at a gold mine.
To answer Evan's question, the '28 one ton with no front brakes would be the model LO. It was only available for the first six months of 1928.
The dump mechanism was not built by Chevy. There were a number of body builders that provided specialty bodies for the Chevy truck back ends. Springfield, Hercules, and Martin Parry come to mind. I don't know if these specialty bodies were sold through Chevy dealers or not. I suspect they were.
