| | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | Will the reproduction cab corners for the 1/2 ton 47-53 bolts fit on the cab on a '53 5100 COE? Any help would be greatly appreciated. | | | | | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | spanky, I found the truck on ebay and had thought about buying it, but the bids went past my $250 budget. I drove over to take a look at the truck yesterday. The truck was in very good shape and the only panel that I saw that would need to be replaced was the cab corners. I believe it was item # 4654065682. | | | | | Joined: Jan 2004 Posts: 34 Member | | Member Joined: Jan 2004 Posts: 34 | Hey Spanky! did yah get to the Baltimore show? I was there. Old Coes Si Lupton I just found a neat :confused: 1940 "F--D" wrecker doodlebug with hand crank hoist and Meyers snow plow! Just had to buy it even if it aint a GMC! :mad: :p  | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Hello Si, I didn't make it to Baltimore, to the ATHS Show. | | |
