2 members (Charles in CA, Otto Skorzeny), 310 guests, and 7 robots.
Topics128,078
Posts1,056,031
Members48,433
#1472061 10/23/2022 12:23 AM
Well... we got the 57 Nomad engine in the 54 3100 today, put the front clip back on, installed the exhaust and got it ready to fire up, BUT... the gas pedal rod did not fit. WAAAH. I used the same linkage from the pulled 216 boss mounted on the front boss of the Nomad 235. Thought it would work BUT it didn't. Thinking about taking the entire linkage off and using the linkage from the tired old 57 6400 back on the rear boss. Thoughts?
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
What seems to be the problem?
I have done this swap many times without a problem.
My Blog
Did you use the front boss or the rear? I took the connection off the 216 and mounted it on the front boss of the 57 235. Couldn't depress the pedal. Geometry did not seem right. Slept on it and will try again today. Jethro.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
AD Addict & Tinkerer
I have a ‘59 235 in a ‘52 3100 and I used the 216 setup on the front boss. Works perfect!
Post some pictures of your setup
Phil
Project Journals
Stovebolt Gallery Forum
I figured it out... the manifold is a low rise 3754644. The 57 261 is also a 3754644. That linkage has a different offset kink to clear the manifold and worked perfect. Also used its gas pedal linkage. Worked perfect.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
thumbs_up
Phil
Project Journals
Couple of picks. 1st is a 216 rod. 2nd is rod designed for the 3754644 low rise intake. Made to clear the intake, and came off or a 57 261 6400.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
OOPS... forgot the pics.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
Jethro, no need to make a second post, just edit your first and add the photos.
I thought I did, but as with all electronic informational gadgets I've used, I failed to get it.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
