8 members (PAUL Berardi, Phak1, DaveV, Cheapskate1229, Otto Skorzeny, carbking, Peggy M, Wayne67vert), 138 guests, and 1 robot.
Topics128,111
Posts1,056,244
Members48,437
The bed in my 65 C20 is completely shot from being parked outside. By the previous owner, My brother. Anyway on removing the rusted hold down bolts. What is the best way to approach this project? Is a torch about the only way. What have you done. The metal strips are still good. and can be sand blasted and repainted. I don't want to destroy the metal. Thanks, Stan
If the heads of the bolts can be grabbed by a vice grip plier, just tighten and twist them off with a socket wrench. Much easier than trying to unscrew the nut all the way off.
I suggest hand wire brushing the threads as much as possible and then heat the bolt from underneath briefly with a propane torch.
Melt a little wax (from a candle) onto the threads and the wax will wick its way up into the nut, providing some lubrication.
Let it cool a little and then the nut should come off without too much trouble.
If the bolt heads are carriage bolts and they start to turn in the wood, take a thin cutoff wheel and grind a slot into the bolt head. Then, you can use a big screwdriver to hold it in place.
Cheers, Dean
Dean 'Rustoholic' Meltz
Lurch: 1927 1-Ton Chevy Cattle Truck
Old and ugly is beautiful! -- The Saga
Lurch's Gallery
Justin: 1928 Chevrolet AB Canopy Express
