2 members (Steelonsteel, Hotrod Lincoln), 136 guests, and 4 robots.
Topics128,109
Posts1,056,261
Members48,439
#1471601 10/19/2022 12:13 AM
Are thermostat housings for the Chevy 235 Inline Six (around 1957) interchangeable with that of the Chevy Small Block V8?
hbarbee,
The answer to your question would be no. See attached pictures below from a couple of current pics found on-line.
Hope this answers your question. thumbs_up
Note that if you are looking for a 235 thermostat housing, just do a search on-line. Numerous vendors/suppliers offer them, both new and used. grin
1955-1966 Chevrolet Water Neck with Gasket 6 Cylinder 235ci 261ci 292ci.png (216.38 KB, 79 downloads)
1955 1956 1957 58-64 CHEVY THERMOSTAT HOUSING WATER NECK OUTLET 8 Cyl..png (164.21 KB, 79 downloads)
V8 thermostat housing
~ Dan
1951 Chevy 3 window 3100
Let me clarify. I am looking to install a water neck riser so I can install a temperature sensor there. So the only issue is if the size and bolt hole placement is the same. They sell risers but they are all described for small block engines.
Thanks.
With your new information in mind, I checked Rockauto.com for "thermostat housing gaskets" for both the 1957 235 I6 and 283 V8.
They list the following T-stat gasket brands and part numbers that are the same for both engines:
Mahle # C24109
Felpro # 35062
Would appear the gaskets are the same, so good possibility your V8 riser may have the same bolt size/placement as the 235 T-stat housing.
An easy step to confirm bolt size/pattern spacing would be to take your 235 T-stat housing to your local Flaps and compare it to a V8 housing to confirm dimensions.
Would be interested to hear about your findings. thumbs_up
~ Dan
I think you’ll find what you’re looking for here.
http://www.langdonsstovebolt.com/store/
Dan
35 CC Case
38 Chevy Pickup
51 3100 AD
58 3100 Apache Fleetside
