4 members (Hotrod Lincoln, Simon1954, Otto Skorzeny, klhansen), 37 guests, and 9 robots.
Topics128,012
Posts1,055,315
Members48,419
#1471555 10/18/2022 7:11 PM
1955 and I think 1956 didn't have them listed on the specification plate. Does Chevrolet tie the serial number to the paint color? I've looked at that GM Heritage site and don't understand it now. Years ago I got a report for one of my 58 trucks and it had nothing about paint color.
Does anyone know anything about this?
Truckrolet #1471605 10/19/2022 12:50 AM
The GM Heritage center website is under going revisions and the Vehicle Info Kits that used to be downloadable aren't currently available. But if you need one I can email one to you.
But up through 55.1 there was no tie of serial number to paint color. I don't think that came into practice till quite a bit later, like in the '70's. The Info Kits thru 55.1 just list the available colors. As and example I just browsed thru the '72 Vehicle Info Kit and it doesn't even have the color chart or names.
Truckrolet #1471612 10/19/2022 1:27 AM
Thank you, the one I am talking about is a 55.2, and yes except for the trucks that have the code on the spec tag there is no color code or record of what it was, just what I have thought anyway.
Are you in communication with that heritage center? It would be interesting what they would say about it.
Do you know what the white paint stick marks that are found on some trucks firewalls mean?
I need to look at my old 58 info kit, if I can find it.
Truckrolet #1471622 10/19/2022 2:17 AM
Yes I’ve contacted the Heritage Center about the Vehicle Info Kits. Hopefully they’ll restore access to them.
As far as firewall markings some members have reported color name abbreviations on their trucks. Usually the initials of the color name.
I can email you a 55.2 kit if you’d like. PM me with your address.
Truckrolet #1471623 10/19/2022 2:27 AM
Legend has it that the chalk marks were made as a truck passed a certain area on the assembly line and a task was finished.
Truckrolet #1471627 10/19/2022 2:54 AM
The paint codes were stamped (typically 3 numbers) on the GVW plate...nothing about paint or trim is found in the chassis/body serial number.
Here's a sample of the paint codes...
Jet Black in 1955 = 637
Jet Black in 1956 = 729
Jet Black in 1958 = 700-A
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I had heard the marks were there to make the assembly line aware of an RPO that needed to be installed...something that wasn't standard issue.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Truckrolet #1471804 10/20/2022 6:02 PM
GVW plate, I called it a specification plate? The other plate (the nice little spot welded stainless steel plate) is the serial number and yes I know never a paint code there.
Truckrolet #1471806 10/20/2022 6:08 PM
You can find all the GM paint codes here.
