| | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2022 Posts: 2 Moderated | | Moderated Joined: Oct 2022 Posts: 2 | I want to change the 17” split rim wheels to a modern wheel but don’t know what to buy to keep the same look. I currently have 7.00-17 tires on it. Any help would be appreciated. Thanks in advance. | | | | | Joined: Mar 2013 Posts: 186 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 186 | A quick way to do it would be to go to 16 inch wheels . 16 inch 8 hole wheels are very common.any auto wreckers will have them, common with all the big 3 manufactors.You might find some with a slightly smaller center hole, no problem,hog it out with a die grinder.Check with wheel companies and I'm sure you'll find 17 inch 1 piece wheels that will work. | | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | Wheelsmith will make any size wheel you want and likely in a similar style as the original.
I had them make up 16" smoothies for me with the original style hubcaps.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Oct 2022 Posts: 2 Moderated | | Moderated Joined: Oct 2022 Posts: 2 | So I switched to 16” rims w/ 215/85r16 mud terrain tires. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Send us a picture so we can see the stance. | | |
