7 members (TexasJim50, DadsFirstPickup, 54farmtruck, Patharr, klhansen, Pete1946, 1955 1 Series),
114
Mod | | | Forums66 Topics128,148 Posts1,056,811 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 100 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 100 | On a 1946 Chevrolet 1/2 ton truck, I just had my steering column completely rebuilt. It was returned to me with the gearbox painted correctly and the column primed (to have final coat) applied by me prior to reinstall. The question on the table is… A recommendation for a supplier of the BROWN color originally used on the column?
Even a particular product recommendation would be greatly appreciated. Randy | | | | | Joined: May 2015 Posts: 11,131 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,131 | Jim Carter supplies the Brown for the 1946 column. LinkIt doesn't specify, but their other paint products are PPG ALK-200. I've used it and it works well. It's an acrylic enamel and sprays well right out of the can.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2010 Posts: 100 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 100 | | | | | | Joined: May 2015 Posts: 11,131 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,131 | I haven’t used hardener in it. But I’ve only painted interior parts so far. I may use hardener on the exterior. It uses ALK-201 hardener. I haven’t found that in anything smaller than a quart. At 1:15 mix ratio I’d have a LOT leftover.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2020 Posts: 35 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 35 | I’m a novice painter Just bought some from carter 57 truck interior gray acrylic enamel ppg Looks thin right out of the can . Have som experience spraying but not with this type. Using a hplv gun. Question is is this paint ready to spray and do you have an option to use hardener? Thanks
57 3105 Panel
| | | | | Joined: May 2015 Posts: 11,131 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,131 | If it's the ALK-200, yes, you can spray it as it comes out of the can. I use a 1.3mm tip and it lays down nicely. You can also use the ALK-201 hardener if you can find it. At a 1:15 mix ratio it won't change the viscosity much, even if the hardener was like syrup. According to the data sheet for it, the hardener delays drying time quite a bit.
