4 members (78buckshot, klhansen, 2 invisible), 147 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#1470431 10/10/2022 12:42 AM
Installed the new 12 V alternator on the 235 then replaced the Dayco #15455 fan belt that came on the motor when I acquired it. The width is narrow and fits well, but it’s a bit too long and there’s no more room on the bracket to adjust out the alternator. I went to the Dayco website and plugged in the data for my 1954 235 to find the correct belt and the result was a #15415. The details show that it’s 4” smaller, which I’m sure will be too small. Can anyone give me the part # of a belt that would corrrectly fit my setup? I’m not particular about a brand. Thanks
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Chuck,
You didn't indicate how much "too long" the #15455 belt is. headscratch
In peeking at the same source site your pictures refer to, these 3 belts all have the same Top width (.44) and Angle (36). Other available lengths are as noted next to these part numbers:
#15425 - 42.5 in effective length
#15435 - 43.5 in effective length
#15445 - 44.5 in effective length
The effective length listed for #15455 is "45.5" inches (you said too long) and #15415 is shown as "41.5" inches (you think too short).
In between those extremes is #15435 at "43.5" inches - maybe just right??? ohwell
Let everyone know what you get and test results please. Pics always appreciated!
Good luck! thumbs_up
~ Dan
1951 Chevy 3 window 3100
The 15455 belt you took off is 45.5" long (the last 3 digits in 15455). And the 15415 is 41.5" long, 4" shorter than the 15455. Get one in between, like a 15435 or 15440.
Unless the working diameter of your alternator pulley is the same as your generator pulley, getting a belt for your '54 is a bit of a guessing game.
Curmudgeon
Curmudgeon
From the Chevrolet Master Parts List: 1953-55 com. (exc. hvy. duty gen.) belt width 3/8", length 41-3/8", notched, part number 3713313.
Crossing this to a replacement belt commonly sold today the length would be 41-1/2".
You converted from gen. to alt.
If alt. pulley dia. and width is the same as gen., use the stock length.
If you installed a modified/conversion belt tensioner, that requires +/- belt distance, then determine what that difference is and recalculate the overall belt length accordingly.
Allow for a small amount of belt stretch.
Thanks everyone for the comments. Dan and Bill, I think the #15435 looks like it just might be the ideal length. You both picked that #, and I agree. I’ll try to find one at a FLAPS. this week to install over the weekend. Buoymaker I haven’t changed a pulley or added a belt tensioner, so all should be stock from what I can tell. I’ll let everyone know how it turns out after I find and install the 43.5” belt. Many thanks!
Chuck
1941 Chevy coupe
