| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 23 Apprentice | | Apprentice Joined: Aug 2004 Posts: 23 | Working on my 46 1 1/2 ton. I need Spring bolts the ones that mount the spring to the axle. Does any one know if the 1/2 ton ones will fit or where I can get some for my truck? | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Our local spring shop makes them up to your specs.She is very good at rebuilding springs too!
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Any good spring shop can get or has those. Take an old one along for size, or they have books if you know all the info. These are the large U-bolts you need?? Much bigger than 1/2 tons. I have had to have mine made up too. Pretty easy to find place for that if needed. Check phone book yellow pages for your area, or call big truck repair shop, see what they do or where they buy.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Aug 2004 Posts: 23 Apprentice | | Apprentice Joined: Aug 2004 Posts: 23 | Found a local spring shop that made them in 10 minutes. Thanks for the help!!! | | |
