1 members (Hotrod Lincoln), 57 guests, and 1 robot.
Topics128,094
Posts1,056,066
Members48,433
#1468675 09/28/2022 4:47 PM
What is the proper type of gear lube for a 1963 C60 truck with a vacuum controlled 2 speed rear axle?
80/90 winter 140 summer or heavy work as much as they hold probably wont change very much
What about the type such as GL 4 or GL 5 or?
Either would work. GL 4 is for synchro transmissions. I don't believe the 2 speed axles have synchronizers. If they do, that would be the only reason to avoid GL 5.
So what is it about GL 5 and synchronizers that is not compatible?
I have been using and maintaining my 1958 and my 1963 Chevy C60 trucks for over 50 years. I'm sure I have added GL 5 to the transmissions not knowing better. I believe it was on this forum quite some time ago where it was stated not to use GL 5 in transmissions. That is what prompted me to ask this initial question about the differential lube.
GL 5 contains sulfur, which will attack the brass used in synchronizers.
58n63 From what I could understand modern gear oil may be too slick to let the synchronizer rings get enough friction on the gear taper to work like they should,may grind on the way in. If the shift collar dogs have weak worn springs so they don't put enough tension on the synchronizer ring may grind. You sometimes feel the collar go past the synchonizer then if you don't go back to neutral will grind. Always happens up town where people will know you don't know how to shift it !! LOL
I believe the OP is asking about lube for his rear, not transmission...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Manual states "16 pt SAE 90 "multi purpose" gear lube.
Made sure it is for hypoid axle.
I run 85W-140 hypoid gear lube.
BC
1960 C60 pasture art
MikeB Well your right kinda jumped the traces there,heard others mention synthetics on gear boxes. Changed my differential 14 pints it then pinion leaked till it got rid of enough is now OK at about i/2 inch below the plug cold.
