7 members (Bill Hanlon, Gdads51, Hugh63c10, moparguy, 32Fordpuchoptop, Hanks custodian, 1 invisible), 182 guests, and 2 robots.
Topics128,114
Posts1,056,283
Members48,439
#1468722 09/28/2022 11:50 PM
I was wondering if its possible to add a vent window to a 1950 door.
I need to replace my door in a 1951 has the vent window and pull down handle the do not make a repo for this year so was wondering if a 1950 door can be used and add the vent window.
How is the vent window secured in the 51 door? In most cars I'm familiar with, the vent wind has it's own frame that bolts into the door. If that's how the 51 is mad it dhould be pretty easy to transfer the vent window frame.
1950 Chevrolet 3100 (Ol' Roy)
Curmudgeon
Curmudgeon
Here is an old link to a couple attempts to make this change. Unfortunately the pictures have expired and there is no indication if either attempt was successful.
You have to consider this conversion may require precision work. Consider rainwater leakage and unwanted air/wind noise from any gaps.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/349630/1.html
There are a number of brackets that hold the vent window in place, one of them at the sill of the window and another at the bottom of the window track on the inside of the door, as well as a couple tabs for screws into the front of the window opening. The inside trim is also notched where the division bar on the back of the vent window goes through it. You'd also need to replace the window regulator, as they're a different style between 50 and 51+. There's also a rain diverter that covers the front edge at the top to keep rain out if the vent window is slightly opened.
If you have your old '51 door you can probably salvage the brackets and window regulator from that. But it might be easier to restore/repair your original door.
Here's a couple pix of the vent window assembly, and the bottom of the window opening showing the bracket at the window sill.
Thanks for the info that helps.
