2 members (delky, Steelonsteel), 235 guests, and 2 robots.
Topics128,089
Posts1,056,141
Members48,436
Page 2 of 2 1 2
AD Addict & Tinkerer
Mine show full at the right side dot, but I can’t say if the sending unit is calibrated. When I approach the left dot, it’s time to get gas.
If you short across the two terminals on the sending unit, that should give you a full empty reading on your gauge, then you will know where the full empty reading is.
Edit: corrected info as pointed out by Bill Hanlon.
Phil
Project Journals
Stovebolt Gallery Forum
If you short across the two terminals on the sending unit, that should give you a full reading on your gauge, then you will know where the full reading is.
Nope, zero ohms is empty.
Thanks for keeping me on the straight and narrow. Corrected original post.
Phil
Project Journals
1950 Chevy 3100 216 3 Speed.
I want to thank you guys for all the input. I feel I finally have it all dialed in using an adjustable voltage drop resister. Filled the tank and made a slight voltage adjustment.
Darren
Current Project - 1950 3100 5 Window with a rebuilt 216 and 3 speed trans
Moderator, Electrical Bay
Great! That voltage regulator looks familiar.
~ Jon
Chevy Darrin, Is that as far as your needle goes on a full tank?
If so, is the first dot Empty?
1950 Chevrolet 3100 (Ol' Roy)
Otto, after I read your comment I went out in the garage, pulled the steering wheel more time and got the needle to move just about halfway over the full square and that’s all there is. I’m satisfied with the results.
Darren
Page 2 of 2 1 2
