5 members (Tronman, Otto Skorzeny, TUTS 59, Millenimech, 1 invisible), 116 guests, and 3 robots.
Topics128,042
Posts1,055,509
Members48,424
#1465400 09/06/2022 5:16 PM
Apologies first - I'm sure there's a thread on this somewhere - can't seem to find it - I have a 57 Chevy 3100, 6 lug that I'd like to do a front disc brake conversion on. It is lowered about 2 inches in the front with monoleaf springs(if that matters). Not looking for power brakes, with drilled rotors - just a basic front wheel conversion kit. What systems do you recommend? Thanks for directing this idiot...
Lots of years ago I used a kit from THIS GUY, a one man shop, on my '57 GMC half ton. Like you, I did not use a booster, but I did use a dual chamber master cylinder (71 Mustang with front disks & built in residual valves) and was happy with the results. What I liked about his product is that he only sells you the specialty pieces and gives you a shopping list to take to your FLAPS for parts like rotors, bearings, seals, calipers and pads. Most of the kit vendors won't tell you what parts they are using and make you go back through them when it is time for brake service. With his kit you re-use the stock hub once you remove the brake drum. Cost is generally lower too.
He is a telephone only guy, no web site other than the advert on Inliners. No facebook, no twitter, no email.
Bill, I’ll presume that like other kits they don’t fit behind stock wheels
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
You could start here: https://www.performanceonline.com/1955-59-chevy-gmc-2nd-series-3100-truck-disc-brake-conversions/
I would also upgrade to a dual master cylinder for front disks and back drums.
don
Don't remember needing to use spacers, but I did give away a set of 1/4" thick spacers to a friend maybe 20 years ago after I had changed the wheels to these:
Buffalo Enterprises (the link Bill H posted above) web page says, "Our Disc Brake Kits DO NOT Move The Wheels Outward".
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks for the info so far. Has anyone used the kits from LMC or Classic Parts?
Not sure how it will work for anyone else, but I have had a miserable experience with SPeedway Motors supplying PPC conversion kit.
PM me if you want details.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
Regarding the fact that they won't fit on standard wheels.... does anyone know if they will they work on Chevy rally wheels?
Mine were Chevy 4x4 1/2 ton Rally wheels as were the rotors and calipers. Fit fine with 235/75x15 tires and no spacers. See picture in post above.
Thanks for the help all!
Check brothers parts. They also have a you tube video for the installation along with the bearing upgrade.
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
I'm running 15x6" 72+ Blazer/K10 4x4 six lug wheels with a CPP kit I bought used for cheap. Could be a wheel option if you're wanting to keep it stock appearing enough to fool most folks.
Thanks!
I don't want to hijack this thread...but I'm hoping Bill Hanlon can provide more details on the year of rotor and caliper that he used for his conversion.
I'm looking to do something very similar on a 39 chevy 3/4 ton truck. I was just researching GM 4WD rotors.
I assume you reused your original hubs and bearings and made a bracket for the caliper.
I want to keep my truck all GM. I don't want Ford Mustang parts on my truck!
Thank you
Brian
