4 members (wilbur53, Stovebolt48, TPR57C, Southerntruck), 135 guests, and 3 robots.
Topics128,115
Posts1,056,288
Members48,439
#1466292 09/13/2022 9:16 PM
What do I need to convert the 6volt distributor to 12v on a 51 ,216? Part #'s
1953 with a 216
I believe at most the capacitor. The points are just a switch and can work at either 6 or 12V.
It is not IN the distributor, but you'll need either:
1. a ballast resistor, a new stomp starter switch with a terminal on the side and a few feet of wire
OR
2. a new ignition coil marked 12v
I prefer door #1 for a hotter spark while starting.
There are some very good reasons Chevy chose to go to a taller distributor cap and rotor when they switched from a 6V to a 12V electrical system. I don't believe the short cap distributor was ever used on a 12V system, at least by the factory. Trying to detail the differences will simply create a big fire hydrant watering contest. Suffice it to say that I won't use a short cap setup with 12 volts.
FYI - After converting to 12v I ran my original 6v ignition coil for almost 6 years before it failed. You might or might not get that out of your if you are looking to save a little money in the short term. When it failed it did leave me stranded on the side of the road so I suggest you change your coil while you are at it. Ballast resistor at Napa Part # ECH ICR13. Coil Part # MPE IC12SB
Dave from Northern Kentucky
My 54 3100
If you put the ballast resistor on I'll betcha the present coil will last for longer than Dave's 6 years.
