8 members (cmayna, baldeagle, Bill Hanlon, Leo, Hotrod Lincoln, Mike in Sycamore, Gdads51, 1955 1 Series),
120
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,280 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2022 Posts: 162 'Bolter | | 'Bolter Joined: Feb 2022 Posts: 162 | What do I need to convert the 6volt distributor to 12v on a 51 ,216? Part #'s
1953 with a 216
| | | | | Joined: May 2015 Posts: 11,068 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,068 | I believe at most the capacitor. The points are just a switch and can work at either 6 or 12V.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2022 Posts: 2,462 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,462 | It is not IN the distributor, but you'll need either:
1. a ballast resistor, a new stomp starter switch with a terminal on the side and a few feet of wire
OR
2. a new ignition coil marked 12v
I prefer door #1 for a hotter spark while starting.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | There are some very good reasons Chevy chose to go to a taller distributor cap and rotor when they switched from a 6V to a 12V electrical system. I don't believe the short cap distributor was ever used on a 12V system, at least by the factory. Trying to detail the differences will simply create a big fire hydrant watering contest. Suffice it to say that I won't use a short cap setup with 12 volts. Jerry
| | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | FYI - After converting to 12v I ran my original 6v ignition coil for almost 6 years before it failed. You might or might not get that out of your if you are looking to save a little money in the short term. When it failed it did leave me stranded on the side of the road so I suggest you change your coil while you are at it. Ballast resistor at Napa Part # ECH ICR13. Coil Part # MPE IC12SB
| | | | | Joined: Jan 2022 Posts: 2,462 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,462 | If you put the ballast resistor on I'll betcha the present coil will last for longer than Dave's 6 years.
