3 members (j05h79, Phak1, Jay R),
73
Mod | | | Forums66 Topics128,154 Posts1,056,837 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 11 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 11 | Hello all. I am pulling my hair out. I installed a three speed BW 10 trans in my 55 series 1 3100. I found and purchased the pull handle and cable but can not find any information on how it attaches to the Pull Arm on the trans. There must be some kind of hardware that attaches to that arm that connects to the cable. A picture would help a lot if anyone has this setup. And information or direction would be greatly appreciated.
Eric 55 3100
| | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Mine has a bolt with a hole drilled for the cable to go through with a flat washer a lock washer then the nut tighten it down Don't have any pics off hand but will look. Hope my explanation helps
This is no longer fun
| | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | Just to expand on what Robert offered. There should be a bracket mounted to the lower bolt on the solenoid. That bracket holds the outer portion of the cable in place. As indicated there is a special bolt with a shoulder type washer that is installed on the OD engagement lever. This tightens the inner cable but allows it to pivot on the lever when it is pulled/pushed. You can fabricate these components and drill a hole in the bolt just below the head. If you have an assembly manual, refer to RPO 315 sheet 2.00 Fred
| | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Just to expand on what Robert offered. There should be a bracket mounted to the lower bolt on the solenoid. That bracket holds the outer portion of the cable in place. As indicated there is a special bolt with a shoulder type washer that is installed on the OD engagement lever. This tightens the inner able but allows it to pivot on the lever when it is pulled/pushed. You can fabricate these components and drill a hole in the bolt just below the head. If you have an assembly manual, refer to RPO 315 sheet 2.00 Fred Thanks for the save Fred I knew the pros would be here to help
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 |
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | EricR Clear back in 1967 on my first overdrive truck ( had a56 ferd overdrive before I knew any better LOL learned on it) I just put a small shifter stick with linkage to shift the overdrive lever. Looked good worked good,looked like a little hurst shifter by the big one. A lot of ways to do it,had a little white ball ,stick about 8 inches tall. | | |
