4 members (DoubleB, greenie-reddy, 41appletruck, Oswald), 85 guests, and 1 robot.
Topics128,091
Posts1,056,038
Members48,433
Page 2 of 2 1 2
Originally Posted by bartamos
Cab floors, cab interior, dash, seat, roof eyebrows, engine bay, better lighting pics...............
Surface rust on frame OK.........flaky metal rust NOT OK....could be mud, could be undercoat coming off, can't tell....believe it's flaky rust.
Which parts are the roof eyebrows and hinge pockets please?
Sir Searchalot
Sir Searchalot
Eyebrow= small outside roof stick-out to shade the windshield/rain drip. Rots under sometimes. There is a patch panel made
Hinge pockets= door hinges mount down inside a "pocket" on pillar. They can rust badly also. There is a patch piece made
Curious about the broken knob left of ignition switch. I was never sure of what would be optioned in that position?
Love the glove box badge. Maybe a 60-61 badging or came with cab package option. I have not seen before. I really like that.
Rust pictures so far are typical and bartamos is centered-alot of time and money to restore. But many of us have started with the condition of this truck.
~ HB
1962 Chevrolet C10
1962 Suburban
Sir Searchalot
Sir Searchalot
Hand throttle. Push/Pull and I guess glove box "Chevrolet" script with Custom Cab. See pic of 1961 for both. Not mentioned in GM Information kit til 1964, as Throttle control/dealer installed accessories.
Also see 1960 Owners manual pic
Used for cold start, PTO, crawling in gear, 4X4 operation.......
Could have been added by owner
Still available as aftermarket
When you mention "patch piece" does that refer to the way it was manufactured or a repair piece?
Sir Searchalot
Sir Searchalot
There are all manner of aftermarket sheet metal repair sections, shaped like the original areas to be "patched", for most common rusted out areas, on most all the trucks covered by Stovebolt.com. Referred to as patch panels. They are relatively inexpensive. They can be trimmed down to be as small as necessary. You cut out the bad rust on the truck and weld these in place. You need to search the internet on this subject. Hundreds of pics and videos. Examples below:
Eyebrow
Hinge area on "A" pillar
Eyebrow
Thanks again. I appreciate the time you've given up to help a stranger. Brightens the soul for sure.
Sir Searchalot
Sir Searchalot
Very nice to hear, Thank you.
Thanks for the references on the glovebox door as well. Good to know.
~ HB
1962 Chevrolet C10
1962 Suburban
Sir Searchalot
Sir Searchalot
thumbs_up
Truck has been sold complete. Thank you all very much for your help and insight. It will stay in Canada and funny enough to the stepdad of my Grandsons friend. Hopefully I can post up some pics once it's done. All the best to you all.
Sir Searchalot
Sir Searchalot
So now you know what it's worth.
Page 2 of 2 1 2
