0 members (), 70 guests, and 4 robots.
Topics128,179
Posts1,057,159
Members48,465
DLBrooks
DLBrooks
Anyone know the correct seals for an sm420 PTO. Looks like 2 that may need replaced - output shaft seal fo The one on the engagement shaft does have a number but the one on the output shaft does not.
1959 GMC 100 Fleet
Follow in the DITY
H Online: Content
Here's a PDF of the National lip seal catalog. I use it pretty frequently to match up dimensions on seals of various types. The shaft sizes of PTO's start around page 55 or so. If possible, try to find a double lip seal, which has a dust barrier outboard of the lip that actually does the sealing. They last a lot longer in hostile environments like where a PTO lives. Good luck!
https://www.timken.com/pdf/7707_National%20Indust%20Seals%20Catalog.pdf
DLBrooks
DLBrooks
Thanks Hotrod.
It looks like ------SKF 5541------ is for the lever rod replacing the original CR 09918-M1.
And --------------Timken 471015-------- for the output shaft.
1959 GMC 100 Fleet
Follow in the DITY
thanks for this guys! super helpful!!!
1965 Chevy C60 Grain Truck
