4 members (k2handyman, moparguy, dt235sd, Hotrod Lincoln), 71 guests, and 1 robot.
Topics128,049
Posts1,055,678
#1461982 08/09/2022 3:08 PM
I was looking thru Rock Auto parts and mistakenly ordered this boot, when I thought I was ordering the starter pedal bellows. Has anyone installed one of these (solenoid boot)? Were they original equipment? How do you install it if so? Is it just a protector from crud?
1953 Chevy 3100
I have recreated my Dad's old work truck with a 5 window.
H Online: Content
Unless you've got a Hydramatic transmission, or a passenger car starter for a vehicle with a key start, that part doesn't fit. It's for a starter with a magnetic solenoid, not one with a foot pedal. The two slots fit over the clevis that is pulled in by the solenoid plunger.
Curmudgeon
Curmudgeon
Thank you Jerry for the info.
1953 Chevy 3100
