| | | Forums66 Topics128,079 Posts1,055,941 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 20 'Bolter | | 'Bolter Joined: Jul 2010 Posts: 20 | Does anyone know of a good distributor rebuilder? I have a 1962 283 V8 that as been rebuilt, I am on my third distributor and would like to rebuild the original distributor. Thanks GW | | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | Cardone. I have a Cardone Dizzy in a '64 Galaxie 500 for the last 12 years. No Problems. https://www.cardone.com/rebuild-and-return/https://www.cardone.com/search.php?search_query=%22K5aVH~%22&year=1962&make=CHEVROLET&model=C10%20PICKUP&Part%20Type=Distributor&sort=relevance Just curious, what keeps happening to your dizzys?
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jul 2010 Posts: 20 'Bolter | | 'Bolter Joined: Jul 2010 Posts: 20 | Well the first distributor had a spot weld break. The second distributor the dwell went out of adjustment in the first two months, so they just gave me a new one. Now the third distributor does the same as second. It will not stay timed. I have been told that one of the big problems with this new distributors come with a set of points that have a plastic rub bar or point, whatever they call it, unlike the old points that had a rub point made of a tuff fiber material. Last week the dwell was at 40 degrees, not running well. The specs for this engine is 28 to 32 degrees. we set it at 30 degrees and it is already starting to backfire on occasion and miss a little. I think I also, need to fine a better made set of points like the old ones, if possible. GW | | | | | Joined: Jul 2010 Posts: 20 'Bolter | | 'Bolter Joined: Jul 2010 Posts: 20 | I forgot to thank you Otto for the lead to Cardone. Thanks GW | | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | I'm so sick of new parts being junk right out of the box.
I just took a new radiator for my Mustang to a radiator shop because it was leaking along the seam where the top tank is soldered. It was 30 days past the 1 year warranty. Made in China, as usual.
The fuel pump on my AD truck was assembled incorrectly at the slave labor camp so that only a 1/16" wide portion of the lever arm was contacting the cam instead of the entire 1/4" width of the arm.
I just sent my original pump to be rebuilt by Then and Now Automotive. Should have done that in the first place.
I hope Cardone does a good job for you on the rebuild of your dizzy.
