Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
4 members (GMCJammer51, Rnl364, Gooberdog, Peggy M), 531 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
#1460303 07/26/2022 4:12 PM
46 Chevy 1/2 Ton 1929 Model A Phaeton
Will the harmonic balancer from my 1946 216 engine fit a 1957 235 engine?
Curmudgeon
Curmudgeon
Will it fit the crankshaft? Yes. Will it be correct? Maybe not.
A lot of the answers can be found by searching Stovebolt.
Initially searching is not easy until you get accustomed to the menus.
I use the Advance Search and customize with " " for just a few words.
Then change Newer Than and Years to blank. Change Older Than to 1 Day.
This is how I found this:
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1024910/1.html
Thanks for the info. I followed the link and read all of it. I think I'm good.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.061s Queries: 14 (0.058s) Memory: 0.5959 MB (Peak: 0.6322 MB) Data Comp: Zlib Server Time: 2025-09-22 12:32:52 UTC
Valid HTML 5 and Valid CSS
