2 members (Peggy M, Gdads51), 106 guests, and 3 robots.
Topics128,169
Posts1,057,043
Members48,458
Junior Member
Junior Member
I am contempating swapping a 83 Chev PU front suspension Into my 48 has any one got any info pitfalls etc. that I should look out for Thanks
48 nick
See this link.
I've done it on two mid-'60s Chevy trucks and am about to do it on my '52 3/4 ton.
Joe
Joe if possible would you be ever so kind to document the swap you do this time and post it for all to see. Thanks.
Send David Hicks home - now!
"Better to be wrong and kill no one then right with mass graves" Albert Camus
Sure will. My son-in-law wants to help with it and will be here over the Thanksgiving holiday, so I'm hoping/expecting it will happen then.
Joe
Junior Member
Junior Member
Hello Joe thanks for the link looks good to me although I've heard from a local fellow that it may be too wide Any comments?
48 nick
Yes, the '73-'87 front and rear ends are wide for an AD truck. They fit fine in mid-'60s trucks.
I'm still wrassling with the wheel question. I was told in another thread that wheels from '93 3/4 ton had a lot of backset, but when I called an all-GM truck wrecking yard the fellow there said no. I guess I'll have to go there with a tape measure next time I'm in the big city.
Since I'm swapping both ends for later model stuff, I can use the same wheels all the way around once I find them. If I can't find a stock wheel that works, I'll have wheels built by Stockton Wheel. They can do pretty much anything, for a price.
Joe
