Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Otto Skorzeny, Peggy M, cmayna), 221 guests, and 5 robots.
Topics128,282
Posts1,058,495
Members48,490
#1458681 07/13/2022 11:57 PM
So today I was told that 1970s era 427 engines made in Canada were externally balanced engines. Engines made in the US were internally balanced for the 427. I have a big flywheel from a 427 that is externally balanced. Plan on using it on a 454 with the original crankshaft. Local machine shop said they can check the balance for me. I would like to have an idea before I drop it off. Do they share the same external balancing?
farms #1458703 07/14/2022 3:43 AM
3B Offline
Hy farms, welcome, are we talking about the tall deck 427s?
3B #1458711 07/14/2022 12:15 PM
Yes. I am putting a 454 into a 1970 c50. The 454 is a 1978 engine according to the casting numbers. Having trouble balancing the assembly with the flywheel that came with the original 350. So have been looking for an externally balanced flywheel for a 454 medium duty truck. Seems the 454 medium duty trucks were only a couple of years in the early 80s. So now hoping this 70s externally balanced 427 flywheel will work for my 454.
farms #1458755 07/14/2022 7:58 PM
3B Offline
Hy farms, what research I have been able to do indicates that the only Chevrolet V8 engines that are externally balanced are the 400 small block and the 454 big block.
farms #1458770 07/14/2022 10:56 PM
Here is a pick of the casting number and the flywheel. My parts catalog only goes to 1969 and only has one part number for the 427 flywheel. So maybe it is after 1969 that they started making some externally weighted?
