Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
7 members (TUTS 59, DES57, BLUEMEANIE, Peggy M, Waveski, 55shaker, Joe W), 535 guests, and 1 robot.
Topics126,777
Posts1,039,282
Members48,100
Most Online2,175
Jul 21st, 2025
#1458090 07/09/2022 8:53 PM
Does anyone know which bumpers go where on both side of the hood? I have flat round bumpers and round bumpers that are about a 1/4" thick, but not sure in what order they go.
This might help.
Pics are long gone, but Denny's explanation should be helpful. That's what I was going to guess - thin on the sides and thick ones up front.
Curmudgeon
Curmudgeon
4 tall in front. 3 short on each side.
Thanks so much, just what I was looking for!
Where in North Carolina are you, I'm just outside of Columbia, SC
Jim
Curmudgeon
Curmudgeon
You are welcome.
Make sure your bolts and screws are in.
Process of elimination, the remaining holes will be for the bumpers.
A tiny bit of lube will help them install.
Above Winston-Salem.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 2.420s Queries: 15 (2.417s) Memory: 0.6104 MB (Peak: 0.6713 MB) Data Comp: Zlib Server Time: 2025-09-22 17:04:06 UTC
Valid HTML 5 and Valid CSS
