7 members (Tronman, Dennys28, 39Master85, dt235sd, carbking, kades51, 1 invisible), 58 guests, and 6 robots.
Topics128,180
Posts1,057,149
Members48,464
Page 2 of 2 1 2
Norcal Dave My 51 6400 pickup is a used (hard) farm truck,no cream-puff in the front end parts. Do what I do,take 2 yardsticks measure your toe-in mid bulge of the tires. Shoot for no more than 1/4 inch less in front than in back. After this setting can run 50 on pretty good hard roads. No problem staying in my lane,comfortable to drive is 98 inch wheelbase.
Thanks fixite7. I did my own alignment with pvc pipes perpendicular on jack stands at front and rear of truck with fish lines running parallel to the truck. Nobody around to help, so I did it on my own and I think the fish line moved during the process….. your suggestion is exactly what I was thinking- keep it simple and use measuring tape on the tread. I’ll give it a go when I get back in town.
I was obsessed about making sure that the steering wheel was straight during the process and I should have probably worried about that last, rather than while I was setting toe-in. I know that you want the pitman arm to be perfectly vertical when the wheel is centered, and that is what I did when I rebuilt the box and put the arm and steering wheel on.
If anyone knows a cheap method of getting your front tires to go left left-right smoothly while adjusting, please let me know. I couldn’t find any lazy Susans at the thrift store. I’ve heard of using plexiglass sheets with grease between them, but haven’t tried it. Perhaps I am just overthinking it all, like everything else?
~ Dave
Back to OP’s topic please! This is not a thread about how to align your truck.
H Online: Content
Drop me a PM, Dave
Page 2 of 2 1 2
