0 members (),
230
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Ethanol converts to sugar, now that's a good one. Don't tell the moonshine guys that.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Wally Montana Remember those funnels with a fine brass screen ?? When I wasyoung on the farm those would catch water in that screen,enough water would block it and gasoline would stand above it. | | | | | Joined: May 2015 Posts: 11,060 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,060 | Wally Montana Remember those funnels with a fine brass screen ?? When I wasyoung on the farm those would catch water in that screen,enough water would block it and gasoline would stand above it. I have one of those and used it recently. It has a sticker on it that warns that additives (ethanol?) can let water pass thru the screen.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
