3 members (55shaker, Hotrod Lincoln, Leo), 92 guests, and 0 robots.
Topics128,211
Posts1,057,468
Members48,471
Question will a 1957 235 out of a truck fit in a 1939 chevy truck ? Mounts ? water pump ? fan ? Need help . Thanks Martin
Except for the water pump and the flywheel it is almost a direct fit. You may need to drill the front plate for the front mount.
You need a 1942 or later flywheel to fit the 1957 crank.
There is also a slight issue with the exhaust manifold. 1939 head pipe dumps straight down. A 1957 235 dumps at a angle.
216 manifolds can be adapted to a 235, or change the head pipe. If you’re truck still has the splash pans between the engine and frame, this would mean the pipe will not go through the original hole for the pipe.
I usually used the 216 manifold on the conversions I did. This is best done with adapter rings in the head to accommodate for the size difference between 216 and 235 intake ports.
My Blog
Thank you for the info . Where do you buy the adapter plate ? Martin
Contact (private message) Pre '68 Dave
Pre 68 Dave Pretty sure I ground the manifold rings flush on a 235 whole manifold and it slipped on the 216 rings,still running anyway Oh 20 years later.
That’s the way my dad used to do it. I made my own rings on my lathe.
My Blog
